Low HP on Engine Data Gauge but Boost Is Proper
2019 Mercedes C43
Hey All,
I have a 2019 Mercedes C43 sedan and its not showing the full 385 HP or getting close to 300+ HP on the engine data gauge. When punching the throttle I am only getting around 200-250HP max. The boost however does go towards the max and does hold.
As a note, the car was making the infamous honking/goose squak in the engine bay a few weeks ago and I had both the boost pressure transducer valve and vacuum check valve replaced, which resolved the noise and helped resolve previous boost issues, however, I am still not able to get close to the high HP numbers (+300HP) in sport + mode.
After some assessment there are many folks on this forum who experienced similar issues, which lead to a many different of solutions:
-Boost leak (however for myself the boost holds and no leak noise)
-Wheel sensor
-Limp mode (Can the car throw a secondary fault if boost transducer was failing which could explain limp mode?)
Has anyone experienced this and any recommendations for a solution to regain HP?
I appreciate all your knowledge and support!
-Wheel sensor
Received 2,725 Likes
Hey All,
-Wheel sensor
-Wheel sensor
2019 Mercedes C43
Hey,
Thanks for replying! Much appreciated.
No idea if there any fault codes as I do not have an OBD reader. I am thinking of grabbing a relatively cheap one or going to my local Autozone for a diagnosis before taking it over to my local MB indy.
No CEL either, just the symptoms I mentioned before.
Nonethless, after reading through many posts on here and other forums regarding similar symptoms, all signs lead to soft limp mode given I recently had my boost pressure transducer failure, which could limit the air intake and trigger a secondary fault code.
Hoping that this is it and my local MB indy can reset software if they have the possibility and reach similar conclusion. Fingers crossed.
2019 Mercedes C43
Ok just did a preliminary diagnosis and only codes that came up were relating to the ABS (Fault codes: B23AA14 and B23AB14). Both pertain to the left and right brake calipers malfunctioning. I have no light indicating this on my dash (i.e., parking brake yellow note or symbol). Seems odd that this would trigger soft limp mode. Can anyone provide guidance on if this seems possible?
Appriciate your knowledge and support!
Hey,
Hmmm you got these codes form AutoZone right? Are their scanners capable in finding MB specific codes?
2019 Mercedes C43
Yup Autozone, wouldn’t trust their MB diagnosis so I am taking this with a grain of salt and will be getting a diagnosis from my local MB indy. I just got the diagnosis from Autozone for my sanity.
Nonetheless, just came back from the gym and pushed the car on my way back and here’s what I have noticed so far.
-0-60mpg in around 6.6-7s (also measured with FastR app no dragy) and I only get to about 300-320HP when punching on throttle and going through a few gears (not from the jump or few seconds); and Im unable to even reach around the 350-80s in terms of HP.
-I am unable to get +200HP when in comfort.
All these could be driver excuses but I am sure the car was faster when I first got it and it definitely feels like it has more potential.
I will be updating this post as I get more results for others experiencing similar problems.
Thanks again, really appreciate the conversation and your knowledge!
Hey,
2019 Mercedes C43
I see, hopefully us forum members can figure it out for you so you can enjoy the car again in whole. Did you happen to kickdown (pedal beyond resistance, click at the end) and still not get full horsepower? You may consider getting a scanner like the Launch CReader Elite Benz V2.0 that other forum members recommend on amazon to scan MB specific codes. It also enables some sort of variant coding as well as a plus.
I just purchased this from amazon online and should be getting it within the next day. I will try doing a self diagnosis with this tool and hopefully get a more conclusive understand as to what it going on before bringing the car in.
Regarding the click point during throttle, I am pushing the throttle to the floor beyond resistance when attempting to make a 0-60 run.
Thank you for your guidance on the scanner tool and really appreciate the support. I am hopeful to get the car back to how it orginally performed.
Hey,
2019 Mercedes C43
Hey all,
I just recieved my Launch Creader (thanks for the recommendation W205C43PFL) and performed a self diagnosis.
Please find the faults observed in images attached below.
It seems that none of these codes would lead to or trigger the symptoms that I am noticing with my car (i.e., not being able to hit high 300HP+).
Nonetheless, I will be taking the car into my local MB indy for my sanity.
Regarding the issues I am noticing:
-In Comfort, I never can get 300s in HP and usually stay within 100-180HP when punching the throttle
-Can hit +300-350 after a few moments of punching the throttle in S+
Also, for confirmation, in regards to some of the codes identified; would “stored refer to faults observed in the past and are not active currently”, while “stored and current” are actual current faults.
I appreciate your time and support!
Indeed the “stored and current” are actual current faults. Being about ESP I would make a quick appointment to dealer ( if you trust Launch). ESP is vey important not only for your safety but for the power as well. Engine always wait specific information from ESP ( tires slippery start, lateral and transversal inclination, etc. ) for releasing the full power.
Also Engine will never release full power if Steering wheel it is not in straight position, Same for firsts and second gear,
Launch is not a legit scanner. The same is Xentry on Aliexpress or ebay or like any other sources beside MBUSA. But Xentry besides the legit/nonlegit part is the most complex and trustful diagnosis software ever created.
And Xentry ( with fake activation ) cost USD100 or something
Hey all,
https://cimg0.ibsrv.net/gimg/www.mbw...46744c8c8.jpeg
https://cimg1.ibsrv.net/gimg/www.mbw...877a717ee.jpeg
https://cimg2.ibsrv.net/gimg/www.mbw...f969ce631.jpeg
https://cimg3.ibsrv.net/gimg/www.mbw...7c10aea1c.jpeg
I certainly do not recommend the fake XENTRY stuff online (personally) but if it works for you, that is great : )
OP, those are indeed a lot of codes, some are voltage related, I am curious, how old is the battery? What about the aux battery?
2019 Mercedes C43
I mentioned Launch because it was tested and recommended by forum members here that had more advanced scanners that cost thousands and the full suite systems including XENTRY including those that they purchased from Peter, yes it is not a replacement for XENTRY no doubt about that but it is the more capable scanners out there that is pocket size at a fraction of the cost.
I am unaware if the batteries have ever been replaced (Ive only had the car for a year and am the second owner).
Scanner reads the battery at 12.3V with ignition off and 13.8V with ignition on. I believe these are within range?
2019 Mercedes C43
Thanks for the support and information!
Any other solutions are not legit at all, but mostly do the job perfectly on a non-professional environment.
And Xentry legit or not can be used with a 20$ interface.
Hmmm, I thought fully charged it should be at 14.6V when ignition on? I could be wrong though.
Although is off topic here, there is no any version of Xentry legit beside the MBUSA or MBEU based on subscription.
2019 Mercedes C43
Did some more research based on the codes that were observed:
-With regards to “U012287”, another poster had similar symptoms that I have encountered (i.e., low HP boost okay in C mode); the poster also noted ESP module being disconnected which indicates fault codes that are similar to mine (i.e., B23AA14 and B23AB14)
>>>Even after having the drive unit and ESP module disconnected/reconnected although the fault codes disappeared; poster stated he was not getting the rated HP: HOWEVER, it seems in manual mode with a tech in the car he was able to get the rated HP
LINK TO POST: https://mbworld.org/forums/c450-c43-...o-codes-3.html
LINK TO ANOTHER POST: https://mbworld.org/articles/mercede...oss-explained/
Given this, I think I will reach out to my local MB indy given the observations that I was able to gather to request batteries to be replaced and “reprogramming” of ECU/ME.
I will definitely give you all an update after consulting with local MB indy. BIG SHOUTOUT to W205C43PFL for his knowledge and conversation to help me drive down to an adequate root cause.
Hey,
Happy to hear you are making progress too and with the research you have done, hopefully you can get to the bottom of this soon so you can enjoy the car again.
If it was indeed a voltage issue, a new battery will solve it (recommend registering the battery to MB's SAM though after you are done), that said, if your indy can test the new battery and see if it solves the issue first before charging you and replacing the battery altogether, that will be great.
That way, if the battery doesn't solve the issue, then you don't waste money on swapping it and still have the problem.
I would also recommend checking the condition of the aux battery too, it is inside the vehicle, on the front passenger side (I forgot the detailed location), it is really a super capacitor and not an actual battery. That failing could potentially cause electrical issues aforementioned as well.
I would also try taking note of all those codes (screenshots of all the codes) and clearing them out and see if it comes back and which ones comes back. The ones that don't come back was historical. Although most says stored and current, it doesn't hurt to try. Your indie would probably do this anyways after changing the battery to troubleshoot.
Another thing, instead of using the scanner to check the battery voltage, check it using the built-in way through the workshop menu: youtube.com/watch?v=mhzGV_l_24g
To get in this menu, you need to make sure you are on the trip and odometer screen, engine has to be off and put the vehicle in position 1. Once you get into the menu, you can start the engine, the menu will stay till the next ignition cycle.
2019 Mercedes C43
My battery with ignition on is about 14.7V and when ignition off is about 12.6V. Please see images below.
Furthermore, while driving today, I did a few pulls in sports+ both manual and automatic.
-In manual was able to get around 360 HP
-In automatic was able to get around 200s HP
-Still unable to get +200HP in comfort and automatic
Given the post that I linked earlier, I am beginning to think that this is the nature of the car (as the poster noted similar concerns that I am experiencing while little to no changes made by MB service). Nonetheless, I plan to clear codes (while retaining a copy of the original codes) and record a few pulls in the different modes at various throttle inputs and upload them for members of this forum to confirm if this is normal behavior of the car.
Again, very much appreciate all the conversation, support, and guidance!
Hey,
https://cimg9.ibsrv.net/gimg/www.mbw...e025f1dbe.jpeg
https://cimg0.ibsrv.net/gimg/www.mbw...da76a57b1.jpeg
2019 Mercedes C43
I see, battery seems healthy but WOT should still bring full horsepower even if not in manual mode, that is the point, like when you press the pedal beyond resistance/kick-down. Your situation reminded me of a discussion a few years back: https://mbworld.org/forums/c450-c43-...ispreloading=1
W205C43PFL, that is the exact post that I had linked earlier in this post conversation regarding similar symptoms that I had observed with my car. Also, that poster has similar U012287 fault code that I have stored. However; unlike that poster:
-I am able to get into 300s HP with WOT in sport+ but not more than that. (Given 385 is in 6500RPM, I think my troubles are psychological at this point, but I could be wrong.)
-Not able to hit 300-385 HP in comfort at all; at most 250-270 HP
For sanity, I have ordered a phone mount to record my speedometer (which I have performance data pulled up) and will be doing a few pulls in both comfort and sport+ (will also try to record throttle input via vehicle data menu to provide side by side comparison). My local MB indy is backed up and I wasnt able to get an appointment until mid next week, so I will continue to self diagnose. Hopefully with some video proof, someone can tell me if my car is performing how it is supposed or if something seems off.
Appriciate the support!
Hey,
