Rear ABC Line left the chat
It has been quite some time since being on the forum, and have missed being here. Life gets in the way sometimes... Kids, sold house, moved, constantly at sea etc.
I have owned my 05 s55 for over 3 years (going on 4 now I believe) and have not even broke the 60k mile mark. The car is always in the garage and is very seldom driven, which in lies part of the problem. She is not driven enough! I came back from sea and decided to take the car out. Upon starting and raising the car, my rear ABC line from the valve block to the drivers rear strut blew (marked with yellow). Thankfully in the garage! Fluid everywhere, but shut the car off well before pump ran dry.
My question's are... What is the easiest way to remove the line as it goes above the rear subframe? I have read some have snaked the line out and others have dropped the rear subframe. Why did the engineers decide to take the line from the drivers side and run it over to the passenger side, just to go into the drivers rear strut? I am sure there is some reason, but why not have a line straight to the rear strut? What would be the harm in having a custom made line go directly to the strut......
Chris
Chris
13 s212 63 p30. 03 s55amg. 06 LX470
Chris
Chris
I appreciate the response Baltistyle. I have a hydraulic shop close to me and will most likely have a custom line done as well as see if they can repair the original line. I will see what they can do.
Many Thanks,
Chris
Many Thanks,
Chris
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
I'd probably run it the same way... I can't remember off hand how the rear lines interact with the return accumulator, which is why I was calling JohnLane.
maw
maw
I appreciate the input Maw. I will most likely go the standard route in replacement as I want to keep the system original. Just was not sure if having the lines ran different (more direct) would make life easier in the long run. No rush on my end as I'm heading back to sea for a short period.
Chris
Chris
I understand Cap'n... if a new route bypassed some damper I would expect trouble... vibration or worse... but I haven't looked at a schematic.
God's speed at sea.
maw
God's speed at sea.
maw
