Aftermarket GPS Antenna Recommendation
Which aftermarket GPS antenna would you recommend? I replaced my Audio headunit with a Comand and am using an Eightwood GPS antenna. I have it behind the hazard/ seat heater buttons panel. I can get four satellites and then it will lose the signal. My E350, with factory nav, gets 7-9 satellites and doesn't lose the signal.I plan to move the antenna to above the instrument pod but am thinking that I would look into a different antenna when making the change. This is in a 2007 CLK350 convertible.
AMGJones0 (09-22-2024)
As I mentioned in my first post, I currently have the antenna behind the hazard/seat heat button panel and plan to to move it to behind the instrument pod because there would be less metal above it. My request is for recommendations for a more efficient antenna than the one I am using now.
I only want to pull the console apart one more time, so if there is a better antenna that the one I have now, I'll splurge and get it. The one I'm using now is an Eightwood. So, if there is a better one I'll get it.
