2013 g63 center diff lock problem
Hi
My center diff locker switch turns orange, but not red.
So none of the two others are working.
I cannot hear any vacum motor engaging, not sure what to look for first. Vacum hoses looks good.
Not sure if the pump is the unit on the firewall, drivers side.
Any ideas where the fuses are?
2013 g63 amg
2013 g63 amg
2021 G550, BMW X5M, 2020 Toyota Supra LE
Hi
2013 g63 amg
2013 g63 amg
Orange means it received the command, red is when it’s locked in. If you aren’t in the right circumstance/situation it won’t lock (as it it shouldn’t) without wheel slippage.
Are you on a low traction surface? Have you tried driving forward and back slightly while turning the wheel? has it ever worked?
Yes. Have done that. Done the same procedure last month, but now it won't engage. Worked last time, after some movement. Can't hear the vacumpump engaging.
2016 G550. Bone stock.
084runnerltd (Today)
