M276 Engine Help removing crankshaft cover
Old Nov 28, 2024 | 05:11 PM
Arlmeroc18's Avatar
2014 C300
I need to remove the crankshaft cover (hoping to remove with most pulleys and stuff I've already fixed staying on) but can get out the woofruff key so was advised to remove timing cover, but can't for the life of me find any ways of removing them for a M276 engine, if anyone can help that be much appreciated thank you!
Old Nov 29, 2024 | 07:58 AM
JettaRed's Avatar
Veteran: Army
see attached
That is the main instruction sheet, but it references other procedures. Let me know if you need the references in steps 1, 2, etc.
Old Nov 29, 2024 | 02:52 PM
Arlmeroc18's Avatar
2014 C300
Originally Posted by JettaRed
see attached
thank you! It just says unclipped ac compressor not take it out? So just should be good we without unscrewing it?
Do you happen to have one with which bolts I specifically need to remove? Cause I know there's some bolts that don't need to be removed which is what confuses me. Thanks again
Old Nov 29, 2024 | 05:45 PM
JettaRed's Avatar
Veteran: Army
Here are all the cross-referenced documents. It does not appear that the A/C compressor is in the way.
Old Dec 1, 2024 | 01:59 AM
Arlmeroc18's Avatar
2014 C300
see attached
Apologies i mislooked at it. Got pretty much everything off except the Power steering pump, do you got any instructions for that? I can't find any other attached bolts
Old Dec 1, 2024 | 09:44 PM
Arlmeroc18's Avatar
2014 C300
okay, got the steering pump off, everything if off and unscrewed, what is the safest way to remove the cover now?
Old Dec 2, 2024 | 08:38 AM
JettaRed's Avatar
Veteran: Army
A little late...
Old Dec 2, 2024 | 07:09 PM
Arlmeroc18's Avatar
2014 C300
A little late...
cover won't budge and as far as I can see all bolts are out, any ideas on removing? Without ruining the cover
Old Dec 2, 2024 | 07:36 PM
TimC300's Avatar
I believe the gasket is a sealant, so will be on tight. Have to carefully pry it off. Im not really much help.
Old Dec 3, 2024 | 03:31 PM
Arlmeroc18's Avatar
2014 C300
Any other advice please, still stuck as glue on there, I've tried 2 different dead blow hammer, crow bar, nothing.
Old Dec 4, 2024 | 03:48 AM
Arlmeroc18's Avatar
2014 C300
Got it!!!
Old Dec 4, 2024 | 09:18 AM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Originally Posted by Arlmeroc18
Got it!!!
It's a great feeling when you finally crack the problem, isn't it? Well done!
Old Jun 16, 2026 | 04:12 PM
pahanorlando's Avatar
Got it!!!
Hey, if you're still here, how did you end up removing the cover? I removed all bolts, but can't get cover to come off. Did you just use blow hammer longer? or any other tricks to let it off?
Old Jun 19, 2026 | 09:36 AM
boyidi's Avatar
I need to remove the crankshaft cover hoping to remove with most pulleys and stuff I've already fixed staying on, but just like trying to navigate marmaray durakları without a guide, I can't for the life of me find any ways of removing them for a M276 engine, if anyone can help that be much appreciated thank you!
Drain the coolant first, then remove the viscous fan, serpentine belt, and front accessory brackets. Loosen the oil pan bolts along the front where it meets the timing cover, remove the valve covers, then you can access all timing cover bolts. For the Woodruff key use a proper harmonic balancer puller tool and note the M276 crank bolt is a stretch bolt so get a replacement before reassembly. Grab a Mitchell1 or ALLDATA manual for your exact vehicle as the M276 has hidden bolt locations easy to miss.
Old Jun 19, 2026 | 10:31 AM
Thanks. I did all that. All bolts are removed, instead of valve covers, I removed upper timing covers and loosen two bolts on each side. I compared to m276 timing covers on ebay and confirmed there are no bolts.
