m113k making strange sound when accelerating sounds like a blow off valve hiss
maw
As for the noise. I'd have to drive it. Engine and transmission mounts fresh?
Replacing all the accumulators is good practice in any 220 with ABC every five years or so. Give it a fresh filter and a rodeo.
ABC leaks? Usually a hose. Remove a leaking hose and have it remade at a hydraulic shop. Any tractor shop or heavy duty shop will do this. Not expensive. Modern materials FTW.
As for the stumble, make sure the fuel pump and filter are correct for the car. Wouldn't help to swap the filter (passenger side near the rear wheel). Often overlooked. Stumble might be fuel delivery. Also check the plugs. Many people run one step colder plugs on these M113k, especially when they're boosted. I certainly do, and the idle isn't as mirror smooth as stock for this reason, but I don't care because I know (or at least I think I know) what it is. Cost of extra boost as far as I'm concerned. Better than having her lean out under heavy load.
maw
maw
Pulleys are par for this course so replace the supercharger pulley already. Depending upon your goals for the car either pulley and tune or just a stock pulley. I know some people replace the clutch bearing but that's a bunch of work for a few hundred dollar part IMO. Pulleys and belts are consumable items on supercharged cars, like fluids and filters.
maw
