2026 AMG GLE 63 S
Old Mar 28, 2026 | 11:26 PM
Fluoroman's Avatar
2026 GLE AMG 63s
2026 AMG GLE 63 S
2026 AMG GLE 63 S — looking for others with similar experience
I had consistent harsh downshifts (3→2 and 9→8) in Comfort mode from delivery. The dealer diagnosed fault P089300 (“multiple gears engaged simultaneously”) and replaced the valve body/controller.
During inspection, there was visible metallic debris on the magnetic filter (not excessive per dealer, minimal sludge in the pan). Required multiple adaptation attempts and flushes before passing, now shifting correctly.
Curious if anyone has had a similar valve body failure with debris present — and specifically whether the repair fully resolved things long-term or if any issues developed later.
Old Mar 29, 2026 | 06:50 AM
OldManAndHisCar's Avatar
I would never let a dealership while doing warranty work define "fixed". With out question "good enough" and "tests good" are not the same as a good solid repair.
Old Mar 29, 2026 | 03:40 PM
mikapen's Avatar
The "Multiple adaptations" is the correct way to perform adaptations. I wouldn't worry about that.
However, debris is a problem.
Old May 20, 2026 | 07:53 AM
AndyA24365's Avatar
mine also does this. Dealer told me it was “normal” I don’t find it normal. I’m going to go to another dealer.
Old Jun 19, 2026 | 08:09 PM
asneiman's Avatar
GLE 63S / GLC 43
My GLE 63 had similar issues. I took it to the dealer 2 weeks ago with 1500 miles on it. They told me it needs a new valve body. Current ETA is mid July. They told me to drive it home, and wouldn't let me keep a loaner. I called 2 other MB dealers, and they both told me not to drive it. I would point out that the told me if there are metal shavings in the filter/oil, they will replace the transmission. @AndyA24365 You may want to ask them about this.
I am now without my brand new $145K car, waiting for a part, and in the back of my mind I am wondering what long term damage may come out of this.
I have a case open with MB, but they won't do anything until after the car has been fixed. Pretty ridicules.
Old Jun 20, 2026 | 08:03 AM
W205C43PFL's Avatar
Was the valve body defective or material fatigue?
Old Jun 20, 2026 | 01:11 PM
Fluoroman's Avatar
2026 GLE AMG 63s
On my repair it was listed as defective.
Old Jun 20, 2026 | 01:23 PM
W205C43PFL's Avatar
Thanks for the follow up OP.
