Heat damage to side mirror housing and trim?
Old Apr 8, 2026 | 09:01 AM
cZ-727's Avatar
Audi Q5, 986 Boxster
Unhappy Heat damage to side mirror housing and trim?
Looking for advice from the group.
New 2026 GLE450, <3k miles. One day all the sudden we noticed right side mirror housing plastic was bubbled up and the plastic trim on car also bulged, likely from heat.
No idea how it happened. Seems most likely from sun damage (?), but this car is parked in our driveway 90% of the time, and i have went out mid-day to check and concluded it's essentially impossible for the sun to hit the mirror at an angle that would cause this, nor is there any reflection from nearby houses. Has anyone ever experienced something like this?
We've parked our previous car in the same driveway spot for 7+ years without issues. Nonetheless, local dealer said MB denied the replacement of those parts under warranty, but they are willing to replace the mirror housing on good will. Which I do appreciate, but the trim piece was not included in this, and from the looks of it, the trim is part of the mirror assembly (i.e. might have to replace the entire mirror??).
What would you do? I'm concerned the bulge on the trim piece would allow water to get in - so I would like to replace it but not at the expense of replacing the entire mirror... would insurance cover something like this?
Just had AC compressor (faulty) replaced a few weeks ago. Hopefully our "bad luck" ends here lol...
Old Apr 8, 2026 | 09:37 AM
Mikes62's Avatar
I really doubt that damage is from the sun. I think it would start to bleach out the color first and not be so localized.
Im stumped.
Old Apr 8, 2026 | 09:41 AM
cZ-727's Avatar
You and me both... I was thinking maybe some electronic elements inside the trim shorted or something and produced excessive heat, but that seems like a stretch as I don't know what would be in there. And the mirror related functions all seem to work fine (adjusting, folding).
Old Apr 8, 2026 | 11:49 AM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Wouldn’t the warranty cover this?
Old Apr 8, 2026 | 12:02 PM
cZ-727's Avatar
Not according to my local dealer. They said MB declined their warranty claim because this is resulted from external.
Old Apr 8, 2026 | 04:32 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
That's definitely heat damage, could be the sun reflecting off the mirror but it's a fluke. The comment that sun damage would first bleach the color doesn't hold true here because that would be UV damage and is a very slow process.
Old Apr 8, 2026 | 05:16 PM
mikapen's Avatar
I wouldn't be surprised if some yokel used a hot pressure washer. Look for more localized damage.
Old Apr 8, 2026 | 06:06 PM
cZ-727's Avatar
I don't think we will get to the bottom of the true cause...
Anyways, I looked up the part, unfortunately it is all one assembly: https://classicparts.mbusa.com/oem-p...ght-1678109201
Dealer quoted me total of $2.7k lol, a quick google search indicated the need of removing door panel to replace it
I think I will ask for a second opinion from another local MB dealer and if all else fails, talk with insurance, or just replace it myself or thru indy shops?
Old Apr 10, 2026 | 03:39 PM
Roweraay's Avatar
X214
This exact same issue was seen within the Honda Passports also, where the plastic in the outside mirrors, showed this kind of damage. Almost looked melted. Essentially, sun damage that occurs when parking outside, and probably related to the specific plastic formulation used in the mirror casing's construction.
Old Apr 10, 2026 | 07:09 PM
benzbell's Avatar
2023 Urus Performante 2018 Huracan Perf. - 2017 Ferrari 488 GTB
This bro had the same problem and the melting even looks the same except it was on the front grille. I remembered this thread from a couple years ago and found it. I think it has to be a weird reflection off some glass or something close by that caused it. I think that was the same assumption and explanation in this thread. Check it out. Very interesting.
https://mbworld.org/forums/gle63s-gl...amg-grill.html
Old Apr 11, 2026 | 01:13 AM
wildta's Avatar
GLE 580
This isn't common but it does happen and Mercedes isn't the only Make with this random issue.
https://www.f150forum.com/f2/trim-me...mirror-411499/
https://www.reddit.com/r/TeslaSupport/s/OcyA296AOD
https://www.reddit.com/r/rav4club/s/AtPM5QZSYX
Old Apr 11, 2026 | 10:55 AM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Space Lasers..............
Old Apr 11, 2026 | 01:23 PM
mikapen's Avatar
I still vote for hot water through a pressure washer.
I've seen that damage and it looks similar.
It can happen to any Chrome plated plastic on any brand.
Old Apr 11, 2026 | 07:52 PM
cZ-727's Avatar
Very interesting read indeed...
I think it must have occurred when parked at other places as our driveway orientation wouldn't make sense for sunlight to be reflected into the mirror.
Why would a hot water through pressure washer be used on the car though?
Old Apr 11, 2026 | 07:53 PM
cZ-727's Avatar
Originally Posted by wildta
That's certainly the most likely cause, for now!
Bummer though that this happened on a 3000 mile new car and from the looks of it we'd have to be the one spending $$$ fixing it...
Old Apr 11, 2026 | 11:11 PM
wildta's Avatar
GLE 580
At least it's in an area that's hardly noticeable. Maybe you can simply sand down the bubbles with various sandpaper grits.
Old Apr 12, 2026 | 02:09 PM
mikapen's Avatar
It used to be common when cars were shipped covered with preservatives, the modern day equivalent of cosmoline. Boilers on the spray machine - unusual today.
Unlikely, but that's what it can look like.
Old Apr 21, 2026 | 07:55 PM
cZ-727's Avatar
Y'all are not gonna believe this...
I took the car to another local dealer for a second opinion. They were very thorough and detail oriented, looked over the car and found that even the mirror housings on both passenger and driver side are slightly deformed! It's really hard to show in the picture but I attached one for the passenger side mirror, you can tell by the deformed reflection where the arrow is pointed at. Obvious if you run your fingers over it though.
They are following up with MB to see if these can get covered. BTW, previous dealer wanted $2700 total for replacing on side mirror assembly 😬
Old Apr 22, 2026 | 11:30 AM
FireRx Captain's Avatar
2020 GLE 350 4Matic, 2016 E350
I'm surprised their giving you any grief on a newer car. Still on warranty. Also removing a door card and replacing the mirror is hardly $2700 even with the labor time. The only explanation I can think of is the mirror assembly is sold as a unit.
Old Apr 22, 2026 | 11:38 AM
cZ-727's Avatar
The mirror assembly is indeed sold as a unit.
Idk man, I think this other dealership might be able to convince MB. Fingers crossed...
Old Jun 17, 2026 | 08:10 AM
BB71's Avatar
Same thing for me
Driver side mirror housing
This occurred out of the blue. I've contacted my dealership and they are giving me the same run around. I've reviewed the Warranty and there is no disclaimer for this type thing.
Old Jun 17, 2026 | 11:20 AM
DCJarvis's Avatar
AMG GLE63s (2024)
It may be related to where you park more than a defect of the vehicle. There was a famous case in London where a skyscraper focused the sun on a car, causing heat damage.
https://www.bbc.com/news/uk-england-london-23930675
Old Jun 18, 2026 | 04:12 AM
RACE_MX's Avatar
GLE55
It could be some kind of chemical got on it, there's a lot of things that would do that but hard to know how it would get there. If you have to replace it yourself I would check eBay and see if you can find one in perfect shape, sometimes you can find just the shell. Swapping out the mirror is easy you can find a diy on YouTube and save some cash.
Old Jun 18, 2026 | 04:50 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Whats the word OP?
Thats its both mirrors is clearly a manufacturers defect.
Mirrors are a safety item and if the structure that is holding them in pace is breaking down and ultimately shifting the position of the mirror, Id report this also to NHSTA, MB Corporate, and the local attorney general.
Additionally, if the dealer can not tell you how it happened, they can not say it happened due to an outside cause. They MUST provide correlation to deny the warranty. It's not your fault they used an inferior plastic that was not fully cured. I guess they are in a contest to see if they can use plastic as thin as a Subaru has...I recently saw a whole rear corner of a brand new model with temp tags, including the taillights that was "wavy and melted" and figured they must have been parked near something hot but not a fire.
Old Jun 18, 2026 | 11:57 AM
mikapen's Avatar
It may be an insurance claim.
