S65 Idle vibration
2015 S65 with 31k miles, no engine-related fault codes.
Mx done so far:
I did a smoke test sealing off both turbo inlets and found a small leak on one IC clamp, but tightened it down - no change.
Car does have fresh motor and trans mount (they were slightly compressed relative to the new ones, but nothing crazy).
A PO had a spark plug change done at about 17k miles (but ~8 years ago).
Issue 1: it has a pretty significant idle vibration that you can feel through the seat and the steering wheel. It's irregular in intensity and pat tern (i.e., not rhythmic), but occurs all the time. Nonexistent when moving / car is above 1k rpm, but as it comes down toward idle from cold start (or even when warm sitting at a stoplight), there's an irregular vibration. I monitored "smooth running engine". Some cylinders have a wider range than others, but I don't see a standard value in the tool (probably my naivety).
Issue 2: Car feels very anemic on 2nd gear acceleration more than half the time (almost like it's NA, more exacerbated at higher rpm). Could be heat soak, but i've experienced it in cool weather (sub 70F). It's an incredibly stark difference (such that it surprises me when it actually pulls like it should). Same occasionally on a kickdown to 3rd for highway passing.
My next bets would be either a coil/plug issue given age, or a vacuum leak, but would love perspective if anyone else has faced similar issues / can recommend the best way to smoke test the vacuum system (tried from the brake booster connector, but either I have no vacuum leaks or there's a check valve I'm not seeing in the way).
TIA!
A failing coil could be an issue as well, masked by the V12 and double spark.
Compression check would also be in order.
Your spark plugs are more than old enough to justify replacement. Be gentle with coil connectors as old plastic likes to break easily. Buy spark plugs from MB to avoid counterfeit plugs. This really is a thing. Spark plugs require less torque when installing than I expected. Do it right. Mercedes offers a sexual lubricant to be applied to each spark plug boot before installing the coils. No dry sex!
they ordered both OEM and the (higher flow?) CWA100 but didn’t want to install the later as it would require adapting the hoses - a project for me later as the car is tuned and will produce more heat - is on offer at FCP right now btw.
i determined it needed the pump as xentry showed high IAT and when I choose actuation for the pump it doesn’t t urn on.
It’s pretty smooth at idle (plugs just done) but it was definitely experiencing some of the acceleration issues he described, including pulling timing and falling flat above 5000 rpm.
you can also view live data with xentry (however saving it is not functional in my Benzninja setup - needs to be fixed) so you can monitor boost and IAT etc during a pull. Use a screen recording to capture.
the weird thing is when I try to actuate in xentry - it doesn’t show that it’s trying to turn on pump 🤔
edit: and yes this doesn’t throw codes (but does pull fun factor!) and I had to convince shop it was an issue as they just checked for codes 🙄
I changed plugs - fixed a valve cover gasket leak at the same time. It was dumping oil on the driver side rearmost cylinder spark plugs (particularly the back one). So bad it had gummed up the spark plug and completely fouled it. Also found a decent amount of oil residue in the PCV hose going to the driver side airbox. Moved the coil from the back cylinder up front so it'd be easier to change if coil is bad. To soon to tell, as the misfire is still there at idle, but there's no misfire codes (and the smooth running idle values are way better across the board with the plug change).
I smoke tested this intake tract, all good there.
I am thinking it's PCV causing the issue with idle at this point? there's suction on the oil cap when the car is running, and I do hear a hiss in the engine bay. Anyone encountered this one before causing a slight idle shake + an intermittent small puff of smoke on startup?
Continuing down the rabbit hole to eventually have an S65 that doesn't just feel N/A all the time
