driver door creaking sound
I havent been able to find the cause.
If you find anything please post back. Im sure more people have this issue.
Thanks in advance
David
i think possibly hinges are bad,ill post some pics later
I was hopping it would be an easy fix ... thanks for sharing. Please post anything you find. I will do the same.
David
pn for passenger is A1667200437
Reason being wd 40 can strip away existing oils.
Would be that bolt removable? I think it is. By removing the bolt, it may be a lot easier to fully grease instead of using penetrating lubricant (stay away of WD40)
Im mwondering if any of you that have replaced the hinge, hav tried this route on the old hinge.
There is a few pictures on this ebay page that can be usefull. https://www.ebay.com/itm/305945624622, https://www.ebay.com/itm/353945112257
I think is even doable as worst case scenario, to buy the hinge to see if there is a fix. It would be way more cheaper than getting the hinge replaced with all the time and billable hours to do that, plus painting the new hinge.
My door does not have any play vertically, If I move the door the hole car moves with it, so the hinge is good, is just the rotating part.
Any ideas are welcome
It must have been wishful thinking. It is not listed. Lube sunroof, check hood hinges, but nothing about the doors. One of the doors is really stiff. Guess I'm on my own...
