SL/R129: Barn Find 500SL Journey
These things were pretty well built and lots of stuff on them just keep on going. Plenty of info on forum for the likely help you need.
Yes distributor caps are an easy remove, wipe all moisture out and air off, after long periods of no use these are likely a problem. After a long time of no use, mine will idle at first start but any hint of throttle to move off causes dying and hard to get going, have to leave a bit. Once its going a good long drive helps a lot. I've replaced mine a while ago, but this reluctance after a time unused persists. This might be not the only thing you have by the looks.
Keep us posted!
