Rear Differential Noise
So a professional rebuild was done, including adjustment. Contact is ok. The noise shifted slightly to another speed and started even without throttle. Now it's after the second adjustment and it does 90-95km/h with throttle and 100-90 without throttle. The flex discs and cardan bearing (original bearing) were also replaced.
So would it be better to buy a used differential or is the defect somewhere else?
https://mbworld.org/forums/c450-c43-...bration-i.html
https://mbworld.org/forums/c450-c43-...ise-issue.html
If you are talking about the noise above, there is really no real fix.
