2019 CLS Build Sheet/Window Sticker
Can someone explain what the highlighted area means? I see it has coils so I’m a little confused.
- Adaptive Damping: The system uses sensors to monitor your driving speed, steering input, and road conditions. It constantly adjusts the stiffness of the shock absorbers to maximize comfort on the highway or improve handling through corners.
- Driver Control: Using the DYNAMIC SELECT toggle switch on your center console, you can manually override the automatic settings to select specific modes (such as Comfort, Sport, or Sport+), which actively tighten or loosen the suspension.
