Re-sealing valve covers without engine removal?
I want to re-seal them but I don't have a lift.
I've done the oil separators (removed front bumper, AC/radiator package to do it), and I know that's a prerequisite to removing the front covers from the valve covers/cylinder heads.
I'm just not sure there's clearance to pull the valve covers off.
Has anyone removed and re-sealed their valve covers without removing the engine from the car?
And I'm wondering if there's some component in the way that I'm not aware of and that can't be removed without removing the engine, e.g. the intake manifolds.
So I'm wondering if anyone's actually done the job.
Have you done the job without removing the engine?
I am wondering that your 2021 er Sealings are bad!
Do you use syntetic oil ?
Are you sure that the sealings are bad ?
Look in WIS ? … there should documented how it goes to replace this sealings.
How much miles have your car ?
maybe someone uploading this pdf for you.
