M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
M275 Experts need your help removing a part of the engine
Old Jun 3, 2026 | 09:55 PM
anton28's Avatar
2023 Rover
I'm working on my 2005 SL65 and have an oil leak coming from behind the crankcase housing, located behind the A/C condenser. From what I've been told, this area used to house the oil cooler on the older M137 engine, but on the M275 it's simply blocked off with a cover and gasket.
I've heard that one of the bolts may be inaccessible without removing the timing chain, and if that's true, the job could potentially turn into an engine-out repair.
Has anyone here replaced this gasket before? Is there a way to access and replace it without pulling the engine? Would removing the front bumper, radiator, and related components provide enough access if the timing chain does need to come off?
Any advice from someone who's done this job would be greatly appreciated.
Old Jun 4, 2026 | 10:51 AM
JohnLane's Avatar
222 S-65
Is that the rear of the A/C compressor that bolts to the housing?
Old Jun 4, 2026 | 06:33 PM
anton28's Avatar
2023 Rover
Yes, thats it.
Old Yesterday | 01:39 PM
JohnLane's Avatar
222 S-65
That guy being at the rear of the A/C compressor says there is no way it could be involved with timing chains. The timing cover is flat across the front of the engine. Timing chains are 2" of space at the front of the engine.
Unbolt the A/C compressor.... Nickel in a bet says it comes right off of there to replace the O-Ring.
Old Yesterday | 02:46 PM
anton28's Avatar
2023 Rover
Ok. Will get to it and report back.
Old Yesterday | 09:29 PM
JustTXn's Avatar
2005 CL55 AMG || 2005 CL65 AMG || 1989 560SEC
Mine has been leaking there too.... I just keep putting it off lol.
Old Today | 09:08 AM
JohnLane's Avatar
222 S-65
*Cracks whip! Get to it!
No excuse for oil leaks!
It is so easy to overthink a task like this.
