S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
glow plug reamer question
Old Jun 3, 2026 | 11:17 PM
mozell's Avatar
I'm replacing the glow plugs on my 84 300sd. The old ones came out pretty easily. I'm having trouble getting the new ones started in the bores. I've applied anti seize lubricant but I just can't get the new ones to start to thread. I assume that's because of carbon build up.I see some high prices for reamers and wonder why you couldn't use a tap of the correct size to ream the bore. If that is a good idea, does anyone know what size and threads per inch that tap would be? The plug diameter on the threaded portion is 10mm. That is the non threaded part. Thanks for your advice.
Old Jun 4, 2026 | 11:06 AM
JohnLane's Avatar
222 S-65
OP get yourself a can of Lubro-Moly's 'Diesel purge' and a selection of wire brushies is sizes that will gently (soft bristles... NOT metal) after being dipped in the can of Diesel purge clean the holes for the glow plugs. Allow them to soak in the cleaner. All will soften up. Patience is a virtue. Compare new glow plugs with old. Be sure they are same-same.
