Transmission stalling and check engine light on after coolant flush?
What are the codes? Possibilities include:
- low transmission fluid.
- failing TCC solenoid.
- failing torque converter.
- failing solenoids on the conductor plate
- failing conductor plate.
- failing TCU
- Can bus fault.
Pull the codes and you will know the direction to go. The W211 can have up to 32 digital modules installed communicating over the bus; one faulty module can bring the whole system down. Or it could just be a faulty solenoid.
Pull the codes.
- failing TCU
- Can bus fault.
Pull the codes.
