What differential fluids are you using?
Im thinking in replacng differential fluids. What alternatives are you guys using vs the MB differential fluid $80 / L ? Car is 2017 GLS63
Thanks in advance
David
Im looking for front and rear differential fluids as well as transfer case. Some states to use the same blue fluid than transmission, and other state to use the old red one which is thicker I think and may be better for a 90K+ miles transfer case.
Any practical recomendations are welcome.
I did a little searching around but got tired of cutting and pasting so its not complete.
I'm unsure if you have the normal "light alloy" rear diff.
Transfer case fluid is easy enough. MB spec 236.12. Shell ATF 134 replaces all 236.12 fluids. I used this in my 722.9 transmission since it was around $100 for 12 quarts.
Rear diff i'm either seeing 235.7 OR 239.71. Either way the Febi 75W85 meets both these specs. I used this Febi gear oil in my W204 front and rear differentials.
Front is where i'm a little confused. I come up with spec 235.75 and when I look at that spec its saying Fuchs TITAN SINTOPOID FE 75W-85. But when i read the info on that gear oil I dont see the spec actually listed on the bottle.
Then I looked on the website where I bought the febi gear oil along with a few other parts for my transmission service and they have a kit for the W166.
Here is a link to that website: https://www.idparts.com/differential...t-p-14738.html
Its idparts.com if the link doesnt work. The site caters to diesel vehicles but obviously things like fluids are the same. I buy from them because they are the next town over and have free order pickup.
