They have different transmissions obviously. Your GLE has a 9-speed and your GL has a 7-speed. They run different software for starters. The 9-speed is also a different approach. It's meant to be more responsive, so it has shorter gearing. The first 6 gears are shorter than all 7 gears in your GL. Shorter gears make for a more direct response and faster acceleration, but it can also increase jerks. Then to get the fuel economy, the 9-speed has three overdrive gears, 7, 8 and 9. In addition, more gears means more shifting. That's especially the case in your GLE 350, because of the small engine. For the 2-liter engine to have any oomph, the turbo needs to spool, so you may have noticed that your transmission has to constantly downshift and upshift to keep the engine in its powerband. The diesel engine in your GL simply has more low end torque, so it doesn't have to downshift as much to get going. Diesel engines are known for their low end torque. IMHO, the combination of the 9-speed with the lack of low end gut of the 2.0l 4-cylinder engine makes for a terrible combination. As said, it constantly has to change gears. I have the 9-speed, albeit a different variant in my C63, but because the V8 has tons of torque it also doesn't have to constantly shift. There's pretty much always enough torque at hand in any gear, but pretty much any MB loaner I've ever driven with the 4-cylinder constantly has to shift. I actually ended up driving many of them in Eco mode. It shifts less and instead sails when coasting. It made for a more pleasant around town driving, or I put it in S if I need it to move. C is just kinda terrible.
