2009 GL450 - Issue; Radio Not Shutting Off With Opening of Driver-Side Door
I have a GL450 and use a key FOB with the push start. When I have turned off the car in the past, when I open the driver-side door, the radio and other electrical screens shut off immediately. Recently this has been hit or miss. If I sit in the car and open the door, the radio will stay on. If I decide to shut the door and open again it will go off. This is an intermittent thing. Sometimes I open the door the 1st time. everything shuts off. Other times I need to close and open the driver-side door again to get everything to shut off. Does anyone have any idea what this might be or if it's an easy fix? I'd appreciate any help I can get with this matter. Thanks in advance.
-Claude
Also, whenever you have electrical problems, make sure the electrical supply, both battery and alternator, are good.
