HELP! Still can't figure this out--from HASH to HASH--DEGREES?
Thank you.
So you can only adjust to +/- 1.5 degrees. I doubt you will see any performance difference if you are off by 3 degrees.
Also if your cylinder head was removed for the dreaded early head gasket oil leak, you do not know if it was installed with precision. I did have a M104 since new and I know the head gasket was replaced at the dealership at only 25K miles under warranty. Not sure about yours. So you see some of the movement may not be stretch at all.
Hope I am answering the correct questions.
