GLE Class (W166) Produced 2015-2019
Code Y3/8n4
Old Yesterday | 12:07 PM
jina's Avatar
2017 Gle350
Code Y3/8n4
New main battery because voltage low codes Prior to and after new battery got quick on off message “do not shift gears”. No limp mode shifts through gears. After battery still getting message quick on and off i. Lower gears and the y3/8n4 code for trans control unit. Any experience with this ?
Old Today | 05:00 AM
amusa's Avatar
16 GLE400 4matic
Sensor/Circuit failure in the Conductor Plate or fluid contamination due to electrical adapter plug and traveling up the wiring harness.
Old Today | 05:43 AM
jina's Avatar
2017 Gle350
I found out my mechanic used the wrong trans fluid and overfilled when I had it flushed 2k mile ago. It was also burnt from overheating. Now, I need a new valve body. In concerned about other internal damage.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
