C63 AMG (W204) 2008 - 2015
AC can’t blow cool
Old Jun 19, 2026 | 09:45 PM
Larryharris's Avatar
2013 c63
AC can’t blow cool
Hi everyone,
I recently bought my 2013 c63 and when I picked it up my AC was working perfectly.
however in the last two days I’ve noticed that my ac no longer blows cold and only blows hot/warm air at equal pressure throughout the car.
i took the car down to a mechanic and they scanned the car and found a fault for the sunlight sensor.
I replaced the sunlight sensor and had them flush and replace all of my AC gas along with testing for pressure and leaks but the problem still persists.
the mechanics say that it looks the the AC fan is spinning and the compressor clutch is engaging
however when the ac setting is set to the coldest it only delivers luke warm air or hot air if the day is hotter. Furthermore when the AC is set to the hottest setting, it increases speed and delivers the correct hot temperature.
This makes me think that there is a problem with the condenser or the ability to cool the air as it functions correctly when asked for higher temperatures
in addition both air con pipes under the bonnet have been hot with no noticeable colder line.
if anyone has thoughts or have experienced this please let me know as I’m currently stuck without cool AC in 30 degree weather, thank you!
Old Jun 20, 2026 | 12:52 AM
Phil_T's Avatar
C63 AMG Saloon
Common failures, getting someone who knows these cars well should be able to tell you which.
​​​​​​ - Condenser
- Pressure sensor
- O ring
Old Jun 20, 2026 | 10:16 AM
LSAMG's Avatar
2013 C63 AMG Sedan
Originally Posted by Larryharris
Hi everyone,
sane model year same issue replaced condenser last year. Get it from FCP Euro
Old Jun 21, 2026 | 10:25 PM
roadtalontsi's Avatar
10 C six trizzle
what are the a/c pressures? if it's not low on refrigerant that it's not a leak. Sun sensor will never cause a/c inop.
Old Jun 22, 2026 | 08:28 PM
Alexie's Avatar
Compressor clutch spinning doesn't mean it's pumping. Both lines hot = no compression happening inside.
Sunlight sensor is a red herring that only affects auto fan speed, not temperature.
You need a new compressor, plus drier and expansion valve in one go. Don't just swap the compressor alone.
If it cycles on/off every few seconds, that's low pressure same fix.
Condenser isn't your problem here.
