W221 AC problem
I’m having a strange issue with the air conditioning on my 2007 Mercedes W221 S320 CDI.
The A/C works only intermittently. Most of the time it either blows warm air or doesn’t seem to cool at all.
Some symptoms:
* Sometimes the A/C suddenly starts working when the engine reaches around 3,500 RPM, but then it may stop working again shortly afterwards.
* Occasionally it starts working while driving without me touching any settings.
* When it does start working, sometimes it stays on for a long time, while other times it only works briefly before stopping again.
* There was one occasion when the A/C was working and I turned the temperature to maximum heat, but it continued blowing cold air (just with weaker airflow).
* I’ve noticed that if I leave the temperature set to the minimum (LO), the A/C sometimes continues working. However, if I increase the temperature even slightly, the A/C may stop working completely.
* Sometimes the airflow is present but the air is warm instead of cold.
* Other times it feels like the system is barely blowing at all.
Has anyone experienced similar symptoms on a W221?
Don't know if it's the same part for the 221 compressor but that would be where I would start. I didn't end up replacing it because after some regular use my system started behaving properly and it's been fine ever since. I think mine was sticky because the car sat for so long before I bought it. It sits on the shelf until my number is called.
- Check for any fault codes that point to the issue.
- Read evaporator temperature, see if it is in fact getting cold.
- See refrigerant pressure at condenser. You should see the presure increase with the ac turned on.
Use a refrigerant refill hose w/gauge to see low pressure. I'm not sure a scan tool will show low pressure side.
- Check low pressure with ac off. Then check pressure with ac on. On a warm day you should see the pressure fall, usually to green marking on standard refrigerant gauge.
You dont mention any lights blinking on the climate control which is good. The ac button light will blink if theres an issue usually.
The compressor could be functioning but if there is not enough refrigerant the evaporator cannot cool down the air passing over it from the blower.
Without a scan tool a simple way to check if you need to top off the refrigerant is connect the refrigerant hose w/gauge to the low pressure port. Warm day it should be reading 50 + psi. Now turn the AC on, if the gauge drops to zero or hardly any you should add a little refrigerant. If the gauge does not move from the first reading further diagnosis is needed.
My AC was blowing hot air when turned on. I connected the hose w/gauge and saw the pressure was low from where it should be on a warm day:
I turned the AC on and the pressure tanked:
This told me at least the compressor is working. I added straight refrigerant, no stop leak stuff, until the gauge was showing around 36 psi.
Air coming out the vents was nice and cold again. I also had my scan tool to see the evaporator temperature was getting very cold. Before adding the refrigerant the evaporator temperature stayed hot.
