P04F0 Error Code
Old Jun 20, 2026 | 03:52 PM
juanalzate0110's Avatar
2019 Mercedes Benz C300
Question P04F0 Error Code
Hi guys!
Wife and I just purchased a 2019 C300 Base model from her father. Apparently they've taken the car to dealership for every maintenance and have never experienced any issues, car currently has ~79,000 miles. The car is completely stock, no modifications performed on it whatsoever. Within a few months of now officially owning it though, unfortunately we got our first check engine light. Error code comes up as P04F0 (Wide Open Throttle Regeneration of the Activated Charcoal Canister Has a Malfunction). The OBD tool I'm using recommends that the fix is the Evaporative Emissions (EVAP) Vapor Pressure Sensor.
I haven't been able to find that part anywhere after a pretty extensive search. Even if I did, haven't been able to find any information or videos on where the part even is on the engine to replace it.
Has anyone encountered this issue before? If so, what should I try to change in order to resolve the issue? Thanks for any help with the situation!
Old Jun 20, 2026 | 04:33 PM
TimC300's Avatar
What engine is that? First have to find out and understand how the system works.
Old Jun 20, 2026 | 04:37 PM
Hi Tim, this engine is 2.0 L, inline-4 engine. I believe it's the M264 engine, google tells me specifically the M264.920 variant. Hopefully that helps, thanks in advance.
Old Jun 20, 2026 | 05:12 PM
TimC300's Avatar
Has any work been done to the car lately, anything?
Helpful to know if someone was recently in the engine bay maybe replacing air filters or whatever. Could be as simple as something not put back the right way.
Can see in the diagram above how it is supposed to function.
Charcoal canister > Purge control valve > Check valve > Venturi nozzle > Turbo.
Can see some type of pressure sensor along the way. I would like to know what this pressure sensor is reading. Can you find anything on your obd scan tool to see what that sensor (17) is reading?
Unfortunately the parts diagrams I use do not have anything with the M264 engine. I'll have to dig a little more.
Old Jun 20, 2026 | 07:04 PM
TimC300's Avatar
Found a TSB that may be helpful.
Says to to check the WOT purge hose as shown below.
Old Jun 20, 2026 | 08:06 PM
smgak's Avatar
C230K
@TimC300
where do you get all your MB diag info? Do you have a xentry subscription?
Old Jun 20, 2026 | 08:36 PM
TimC300's Avatar
No Xentry. I have yet to need it.
For free online manuals I use the link here >>> https://lemon-manuals.la/
It has all the Mercedes manuals as well as numerous other makes. Takes some time to learn to navigate the sections to find what you want. Somewhat limited info on later models like 2023 +.
For parts diagrams I use >>> https://nemigaparts.com/cat_spares/epc/mercedes/
Old Jun 20, 2026 | 08:52 PM
smgak's Avatar
C230K
Sweet thank you for sharing your resources!
