About To Purchase 2009 C63 Need Advice/Tips
What's up everyone. I'm in the process of purchasing a 2009 Mercedes-Benz C63 AMG W204 with 60,000 miles and I want to make sure I go into this the right way. I've done my research but I wanted to hear from actual owners and enthusiasts who know these cars inside and out. Most banks are declining due to the vehicle's age. Has anyone successfully financed a W204 C63 and if so what lender did you use? Credit unions? Personal loan? Any specific lenders that are known to work with older performance vehicles?
What should I specifically be looking for on a 2009? I know about the head bolt issue on pre-2011 cars — what else should I have an inspector check? Any known problem areas on this year and mileage? What should I budget for maintenance and ownership on one of these? Any surprises you wish someone had told you before buying? Anything else you wish you knew before buying your C63 — I'm all ears.
Appreciate any input. This community knows these cars better than anyone and I want to make sure I'm making a smart decision.
Also if I cant get that one what is the highest possible mileage I should consider buying I definitely buy a higher mileage one flat out but not really keen to buying a car with 100k miles.
My 2 cents:
the stock suspension is absolutely horrible for something so powrful and well its a 2009 so u got some age but the questionbecomes how were those 60k miles driven. cracked springs in rear very common. coiover upgrade was best $$ ever spent. Lots of little things that are relatively cheap and IMO the w204 is super easy to work on vs most esp anything newer. Never left me stranded but if i had to bring my w204 to the shop everytime yikes totally not worth it and if your financing it with monthly payment just tread carefully and dont push it if you dont have info on history.
At 60k i had to rebuild the transmission in mine and while that seems to be no so common at that milage **** happens
