Mystery Goop
It’s been a while since I’ve posted! My GLK has been working very well, with no major issues. I had to replace the blower motor controller/resistor, which was fast, cheap and easy.
On to the mystery goop, the main topic of this post.
One time this past winter I saw a small trail of sludgy looking black goop leading into the GLK garage side. Put the car on the lift and didn’t see any source. I checked all fluid levels, and all were fine. The color and consistency of the goop led me to believe it was not a typical fluid, but more likely an accumulation of road grime mixed with some…something…maybe ectoplasm from Ghostbusters. It happened again a couple times between then and now, with no obvious source of the goop. I replaced the rear rotors and pads yesterday along with engine oil and serpentine belt as part of regular maintenance. I decided to spend a bit more time poking around the front end, and I found the culprit. It was (still is) the passenger side control arm bushing. These are fluid-filled on these cards.
It should be a pretty straightforward job. Any recommendations on manufacturer? I’ll likely go with FCP Euro or AZAutohaus as a source.
Thanks,
The original parts lasted 14+ years.The quality of replacement parts has really gone down the tubes.
[Edit] Oh, by the way, if you have AWD, the Lemforders are a Chinese puzzle to fit in. FCP sells another manufacturer (Febi?) that has a different shaped ball joint that reportedly goes in easier.
