steering wheel not centered with steering rack center, how to center?
pretty sure the steering column wasn't centered with the rack when put together. I have rack center marked on the steering wheel and have ability to do the work, but haven't worked on benz rack before.
is there enough play in the column for steering column knuckle be pulled off the steering rack splines and realigned without dropping the rack?
or
can the steering wheel and clock spring be re centered on the steering column or is there a single key orientation on the column for the wheel and clock spring?
The main screw holding the steering wheel to the column is a 10mm Allen (female hex). You'll also need a "long" (longer than a socket) T-20 (I think) for the 2 screws accessed from the back of the steering wheel.
