SL/R129: Just bought a hard top but now problem
Hi all, I have an R129 SL 500, year 2000 model. I just recently purchased hard top for it and tried to install it. I put the top on aligning all the pins, and pushed button forward and it seems like it locked the rear of the top in place but the front part did not lock in and light started blinking.
So I manually locked the front using the tools in pouch and turned those screws behind the visors and I managed to lock the front as well. Now the top is secure, and the light turned off, so I thought all was well.
So I start driving, and a minute after driving, the damn light turns solid red again and an alarm sounds. So It's been like this since. Why is it misbehaving and what can I do to fix this.
Thanks.
Thanks.
'87 560SL Sold, '99 SL500 For Keeps
All the hard tops have rear defrost connectors so they can be unplugged when removing the top Even if the connector fits the receptacle, you still can't be sure from that what year the top is from.
Bob
When you first put the hardtop in place, did you place the front "prongs" in the holes and all the way down? For safety design, they won't lock if the prong does not press against them.
When you manually lock them, the switch might still think it's open; hence the red lights and the "ping". Were there 9 pings then they stop?
BTW, are there any leaks in your cylinders? Is your reservoir level up to the max mark?
1992 500sl
There is a difference in the top from 1995 on that has to do with a sensor in the very front center of the top. It is a magnet with a hall effect sensor that opens and closes a switch to tell the computer that the top is in place. Check what ever information you have on the top and see if it isn't a 1994 and older top. There may be a way to place a piece of metal in the top so as to complete the circuit.
Wow, I was wondering how the computer/sensor "knew" if I put a newer top on or not but cdrusn, your post explains that I guess.
I do notice the plenty pings, I haven't exactly counted but 9 sounds about right. I have not checked for leaks or reservoir. The soft top works without a problem so I haven't needed to check.
About the prongs in the front, I'm not sure HOW much I have to push down. It seems to not want to budge with force. But maybe I haven't tried hard.
