SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: G force: call for opinions
Old Jun 29, 2013 | 06:45 AM
SamuelP's Avatar
sl500 1995
G force chip and claims - improve performance and gas milage.
True or bogus? Or, marginal positive. Or, does nothing at all.
Opinions based on knowledge or experience?
Old Dec 16, 2013 | 11:44 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
What is G force? As a driver, pilot, reluctant roller coaster rider, and student of physics (50 years ago), I have a concept of "G's" but am clueless about your question. what's up?
Old Dec 19, 2013 | 08:39 PM
Scrambles's Avatar
2003 E55, 1997 500SL
He's talking about a chip tune, g force is the brand name.
I have no personal experience with them but from what I've seen on the web they're a scam.
Old Dec 20, 2013 | 01:22 PM
cliffyk's Avatar
1998 SL500
Inside of that impressive box is a 3¢ resistor that you wire to the engine's IAT (Intake Air Temperature) sensor--either in series or parallel depending on the nature of the ECU's input configuration. This will fool the ECU into making the air/fuel ratio leaner (or richer) when operating in open loop mode (higher loads and WOT).
The ECU can be tricked into making the mix leaner by making the IAT report a higher intake air temperature, or richer by forcing it to report a lower IAT. Which is chosen for any particular engine is based, for these silly devices, depends on what that engine's control system does at high loads and WOT. Most modern cars run a bit more rich than would be optimal to protect the engine by lowering combustion temperature; so a common cheap tweak for years now has been using the "resistor trick" to make the ECU think the intake air is warmer than it really is--the ECU sees this and leans out the mix just a bit.
The leaner mix reduces any bogging caused by the "stock" richer mix, and if carefully done can improve both power and economy--however this is accomplished at the risk of increasing combustion chamber temperatures AND the risk of engine destroying detonation.
How "carefully" it might have been done by an eBay vendor, relative to your engine's specific needs, falls quite squarely into the "Do you feel lucky today?" category of life's decisions...
Here is an analysis of a similar device I did a few years ago.
