SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: R129 Soft Top Rear Lock Problem!
Old Aug 30, 2015 | 01:08 PM
Top Hydraulics's Avatar
SPONSOR
03 SL Kleemann, 97 SL320 pano top, 95 Lorinser E320 Cabrio, Ferrari 360, Tesla X
Originally Posted by VilleVantaa
Hi Klaus,
and thank you for help. Reason why I ask about RST-module, was that local MB dealer
guessing that could be reason why lock's won't work. We have so few SL's in Finland, it's really hard get help to problems at local dealers.
I also misslead because there is not any loss of hydraulic fluid.
It is also weird, that after 2-4 tries ht-roof rise and lock up, when I open it.
If there is bypass in rear locking cylinder's, could roof still work sometimes? After multiple tries?
What you think, should I change all locking cylinder's at same time or only the faulty ones?
Ville
FINLAND
Hello Ville,
obviously, I cannot give you a perfect diagnosis based on what you are writing, but the likelihood of my previous response being correct should be close to 99%. Everything you are describing is consistent with internal bypasses.
You will not necessarily have external leaks if there is an internal bypass, and internal bypasses will not result in codes from the controller.
One thing leads to another. There are eight cylinders in your '89 that are in imminent danger of having the piston seals falling apart, based on what I'm reading. You not having any external leaks yet is an extremely rare case for an R129 - you must live way up North. Any of your twelve cylinders may be leaking externally very soon; you have been very lucky so far. A further complication is that fragments from disintegrating piston seals can impact the valve blocks under the roll bar, and that's where diagnosis becomes ugly.
My honest, best advice is dealing with all twelve cylinders at the same time. Send them in for rebuild service, and it will cost you only $550 plus shipping. Even with all cylinders attached to the locks, return shipping by International Express Mail (EMS) is only $80. We ship internationally every day.
Klaus
www.tophydraulicsinc.com
Old Aug 31, 2015 | 08:41 AM
FalconChief's Avatar
1996 Mercedes-Benz SL500
Chang the all!
I just changed all 12 of my cylinders in my 1996 SL500. They were rebuilt by Top Hydraulics. After putting my system back together and topping off the hydraulic fluid I found a leak in the distributor! I would change the seals in it as well. Once these seals start to fail they will all fail eventually. Unless you enjoy removing & replacing cylinders I'd do them ALL at the same time.
Once everything was replaced I had to cycle the top 6 or 7 times to get the cylinders all in sync & primed with fluid. Top works just great now!
Old Sep 7, 2015 | 07:31 PM
SPONSOR
FalconChief,
thanks for sharing! We don't want people to think we are trying to up-sell them when we suggest that they have us rebuild the front distributor p/n A 129 800 00 22 at the same time as the full set of cylinders. That's why we recommend to do the distributor upgrade for ANY R129 SL that is 20 years or older, and also for those younger SLs which are or in a hot climate, or have been there for a while.
Maybe we should be a bit more aggressive with our recommendation regarding the distributor, seeing how many distributors we are getting in from younger cars lately.
Rebuild & upgrade service for the distributor only: http://www.tophydraulicsinc.com/en/r...indshield.html
Rebuild & upgrade service for the full set of cylinders with distributor: http://www.tophydraulicsinc.com/en/r...stributor.html or http://www.tophydraulicsinc.com/en/r...stributor.html
Rebuild & upgrade service for full set of cylinders only: http://www.tophydraulicsinc.com/en/r...-set-r129.html or http://www.tophydraulicsinc.com/en/r...-set-r129.html
Klaus
www.tophydraulicinc.com
Old Sep 12, 2015 | 09:17 AM
VilleVantaa's Avatar
500SL
Hi again!
Today I dissemble all 12-cylinder's. It took 4hrs, and it was quite easy with TH's guide.
Only problem was with right main lift cylinder. Bolt, wich is bottom of cylinder, broke.
So I think there is no way to get it off. Luckily there is enough space, so I can open cylinder and
replace only o-ring. Or do anyone have idea, how I can get that broken bolt off?
Next I will pack those cylinder's and sent to Klaus and wait new ones arrive.
Ville
Old Sep 12, 2015 | 05:26 PM
SPONSOR
Broken lower main lift cylinder bolt p/n 129 991 02 12
Ville
Ville,
on model years 1990 and 1991 (also model year 1989 in Europe), Mercedes used a poorly designed bolt for the bottom of the main lift cylinder. It requires an 8-mm Allen wrench (inside hex bolt). Poorly fitting wrenches might slip and wear out the inside hex. Even if the wrench is a tight fit, you may end up with a cracked head on the bolt, in case the bolt is threaded in very tightly. This is rare, and there are several ways to deal with it. More detail can be found in the following thread: http://www.benzworld.org/forums/r129...nder-bolt.html
Here is a picture of such a bolt with cracked head:
How to extract the broken bolt:
1) Use a special 14-mm tool that latches on to the outside of the bolt and allows you to extract it. A customer told me that it worked great for him, but I cannot remember the brand or exact name of that tool.
2) Hammer a 13-mm socket onto the outside of the bolt, and extract the bolt that way. Here is a photo of how BenzWorld's "aam" did the job:
The extracted bolt:
How the 13-mm socket fit onto the outside of the bolt:
(If this fails, then you can still saw off the bolt with a very fine blade right next to the cylinder bottom.)
I hope this helps. The replacement bolt from Mercedes is p/n 129 991 02 12.
Klaus
