SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Fuse 1 blows (engine compartment)
Old Sep 26, 2014 | 08:46 PM
macgilver's Avatar
320sl
95 320 sl blows #1 fuse when the headlight switch is turned on. The diagram for the headlight switch is confusing. Can anyone tell me which pins are connected to pin5 when the switch is turned on. There is a dead short on one of the output pins. Lamp control module is ok.
Old Oct 5, 2014 | 02:25 PM
cliffyk's Avatar
1998 SL500
I believe it is the the right tail/parking lamp; this based upon fuse 1's connection to the lamp failure module (N7) at connector 3, pin 6--labeled as "Circuit 58, right tail/parking lamp fused voltage input"...
