SL/R129: What is the tank underneath the wiper washer fluid tank - 1995 SL500?
There is a tank inside the front passenger side fender right below the wiper-washer tank and she broke off the front tab so I'm guessing I need to replace that tank but I don't know what it is. I tried searching here and on google and I'm at a loss on this one...
This is the tank that I'm talking about. It looks like it is just receiving any fluid the escapes from the coolant expansion tank under the hood and that the car doesn't do anything with this fluid afterwards.
If so can I just remove this tank and let any runoff drip to the ground?
If you remove that overflow tank excess hot coolant will flow to the ground. And when it cools down no coolant will return to the expansion tank/radiator because it was thrown out of the system. As a result, you may need to constantly add coolant to maintain the correct level.
