SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 2000 mercedes sl 600 - check engine light throttle motor replaced still lacks power
Old Oct 25, 2015 | 02:08 AM
anish somani's Avatar
sl 600
Anyone help me with the issue of no power with my sl 600. I had to have both throttle motors replaced and car not running smooth at all. No power has issues with getting any speed. Fuel filter replaced. Had this work done at a mechanic who is good and I trust. He says I need to take it to Mercedes Benz dealer to reset the programming? Is this correct. Please help.
Old Oct 26, 2015 | 05:50 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R129 forum...
Old Nov 16, 2015 | 03:30 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
yes! Go to a place that has the star diagnostic ability.
The engine is in the LHM (limp home mode ) and a detailed read out will lead the mechanic to the correct repair!!!!
You may have needed the stuff that was replaced but until the system is diagnosed it is just a guess.
Old Feb 1, 2016 | 01:53 PM
Fast dragster's Avatar
98 SL600
I have same issue. I found several broken small plastic vacumm line so replaced all. Now I just need to sync or calibrate the throttle pedal to this later design "DRIVE BY WIRE" style throttle bodies.
I know dealer ship has Star, but I dont need diagnoses because I fould the broken parts. Just need proceedure to reset. Someone mentioned but was not for this model, a way to do by pushing pedal in a certain sequence. ????
Old Feb 1, 2016 | 04:26 PM
98 SL600
You may want to check out: victor@restoreyourmercedes.com
