SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 95 SL320 convert roof problem
Old Sep 20, 2016 | 11:16 PM
Bob M's Avatar
1995 320SL
I moved my car outside today with the roof down. It has been sitting inside for about 2 weeks, I went to put the top up and it stopped half way.
Fuses are all good, I charged the battery( which I think needs to be load checked, it's about 5 years old).
No hydraulic leaks and the reservoir is full.
My best guess is the battery is shot or it's a mysterious relay.
Any advice is always appreciated.
Old Sep 22, 2016 | 09:25 PM
rich8566's Avatar
Start the car and keeping it running while you operate the top.
Old Sep 23, 2016 | 08:26 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by Bob M
...I went to put the top up and it stopped half way.
This typically indicates that the windows are not "synchronized". If you open a door and the window does not lower 4mm automatically, then this too indicates the windows are not synchronized.
You synchronize a window by pressing the switch to raise the window and once the window is all the way up continue to press for an additional 2 seconds.
Old Sep 23, 2016 | 09:41 AM
Bob M's Avatar
1995 320SL
The battery was load tested and okay.
I started the car and tried to sync the windows, but nothing works, windows top, roll bar, nothing.
i removed the battery yesterday, hoping that will reset something...so far nothing works.
Old Sep 24, 2016 | 12:00 PM
bobterry99's Avatar
The most likely explanation is that you have a blown fuse. Check all fuses in general and particularly fuse #6 in the main fuse box and fuse #3 in the trunk.
Old Sep 30, 2016 | 10:51 PM
Bob M's Avatar
1995 320SL
Problem solved.
1 removed the battery and had load tested, it was fine, Charged it.
2 manually locked the roof down, front header, tonneau cover, rear top.
3 reinstalled the battery ( fully charged )
4 ran the windows up 3 times
5 with windows up, cycled the roof up and down and up again
6 with the windows up, opened the door to see if the window dropped a 1/4 of an inch like it should.
Its a miracle, fixed in time to put the car in storage
