SL/R129: Front Wheel Bearing
Front Wheel Bearing
Front right wheel bearing is bad (has a play). Front left wheel is fine. Do you guys recommend changing both or just the one that is bad?
I looked at replacing the wheel hub assembly rather than just the wheel bearing (although more expensive, seems less risky to me as DIY).
Got part 129 330 0625 from the dealer but cannot find this part online. I found 209 300 0325 instead, but no indication it will fit
Thanks in advance for your help
