Alternator regulator replace
Hello i'm trying to replace my Regulator on my alt book says use a 19 mm socket to loosen the adjuster pully.mine has what looks like a male torq bolt small like 9 mm is this what I need to loosen to remove serpentine belt?? My car is a 1994 sl500
Thanks for any help.. |
If you want the correct procedure post your VIN!
Alternator reg replacement
Ok..WDBFA67E1RF100323
Thanks |
1 Attachment(s)
Originally Posted by SLman61
(Post 7228919)
Thanks I am confused on this one, in any event see attached, be patient in determining your application:eek: |
Regulator removal
Thanks for the info..
