SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Cam magnet sealing
Old 03-07-2018, 10:40 AM
dsentel's Avatar
1998 sl500
Cam magnet sealing
I've sealed the face on the cam magnet to stop the oil leakage 3x now. Recently I invested in the MB sealant, but I have the same problem. The seal is good for a few days and then it starts leaking again.
I have cleaned both surfaces very thoroughly and applied sealant where it appears to have just the right amount of ooze (sp?) around the outside.
Wondering if I need to let sealant cure before assembly, sealant on both surfaces, tightening too much, or maybe the faces are warped enough I need new parts?
Luckily it is an easy job but I am getting tired of it
Thanks.....
Old 03-09-2018, 12:41 PM
dsentel's Avatar
1998 sl500
Cam Solenoid
This is the cam solenoid on the front of the engine that has a flat face seal. I have read many posts about issues with sealing and thickness of sealant. Will try letting sealant cure for 2 hours before mating surfaces this time if there are no other suggestions.
Quick Reply: SL/R129: Cam magnet sealing
