SL/R129: 91 300SL ignition lock stuck
My 91 300SL is inoperable due to a stuck ignition lock.Locksmith says no can do on site and my mechanic wont mess with it.
Any suggestions beyond using the dealership would be greatly appreciated.
I am not a man of unlimited means.
Sincerely,
UGGHH!!!
I presume your problem is that you insert the ignition key and it will not turn. I suppose its possible the key is worn and a new key is the solution, but I think it's more likely that the lock cylinders are worn. If that is the case, then you need to destroy it by drilling it out. Then you can use a screwdriver or other implement to turn the ignition one "click" over to "Position I" (see owner's manual) and remove the ignition switch assembly for replacement.
