SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: CENTER AC VENTS WEAK
Old Jun 11, 2022 | 09:02 AM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
The center AC vents on my 98 SL500 are very weak the side ones blow fine. Any ideas where I should look for this issue?
Old Jun 11, 2022 | 11:16 PM
BenzBopper's Avatar
06' Audi Quattro, 00'SL500
This way you can see if your cable is broken or fell off the open/close flap.
Old Jun 12, 2022 | 06:56 PM
FATHERTIME's Avatar
Fixed it!
Cracked distribution block. A little Gorilla epoxy and good as new.
Old Jun 12, 2022 | 10:54 PM
BenzBopper's Avatar
Way to go! I had a cracked hose at the purge valve, two little cracks on the at each end and a 1/2 hole on the bottom just sucking all kinds of air. I changed out quite a few cracked hoses after that episode as preventive maintenance. Cost me about 3 hours and 5.00 bucks in hose.
Old Jun 15, 2022 | 10:48 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Yup, was gonna say replace but you went a step further.
