SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: (Half) Dead Cluster, Rough Shifts, and P1747
Old Jan 13, 2025 | 08:31 PM
ChoonHound's Avatar
1997 SL500 “Sport”
Hi folks. Question for ya…. Obviously there is a CAN bus / electrical / data issue occurring here. Suddenly, and unpredictably, my 1997 SL500 will throw a CEL (P1747), lose several gauges, and show an ASR and Oil warning light.
Obviously this is a wiring issue of some kind, not a mechanical one. The question is: what is supplying this data to the cluster and the gearbox simultaneously?
Any help appreciated!
Lucas.
Old Jan 14, 2025 | 02:14 AM
AndreasHannover's Avatar
SL600
At least one of the fuses is gone, easy to find in the fuse box. But there is a reason for this you have to find, fuses doent blow for no reason. Check the lights at the inside mirror for a short, check the door mirrors inside insulation and the third stop lamp.
Old Jan 14, 2025 | 10:43 AM
ChoonHound's Avatar
1997 SL500 “Sport”
I don’t think it’s a fuse. The issue goes away after a shutdown and restart, but always comes back.
Old Jan 14, 2025 | 02:11 PM
SL600
And what if you take a quick look in the fuse box? I dont guess, i know (guess why ) What about the three possible errors in listed above? Do they all work?
Old Jan 14, 2025 | 03:03 PM
ChoonHound's Avatar
1997 SL500 “Sport”
Despite being an illogical culprit due to the intermittent nature of the issue, I would love for the cause to be a blown fuse. So I checked. Every. Single. One. They were all fine. What else ya got?
Old Jan 15, 2025 | 03:23 AM
SL600
What about the three possible errors in listed above? Do. they. all. work.?
Old Jan 15, 2025 | 10:11 AM
ChoonHound's Avatar
1997 SL500 “Sport”
I’m sorry, I don’t follow. All the lights seem fine, except the dome lights which are blown and have been. Is that what you mean?
Old Jan 15, 2025 | 12:21 PM
SL600
If there is a short, this will be the culprit. And you need to find the fuse that is falsely pretending to be good.
The R129 have no Can-bus, beside a very short connection inside the module box.
Old Jan 20, 2025 | 12:57 PM
ChoonHound's Avatar
1997 SL500 “Sport”
I gotta apologize. Ever since I reseated all those fuses the issue hasn’t reoccurred. Huh. I’ll be damned.
Old Jan 20, 2025 | 01:48 PM
SL600
It's OK, you're not done yet. There's a reason the fuse blew, so be prepared to experience the problem again. The lamp housing on the rear view mirror may have become brittle, if you get a chance I'd check for a short there.
Old Jan 20, 2025 | 01:51 PM
ChoonHound's Avatar
1997 SL500 “Sport”
It didn’t blow.
