SL/R230: LOWERING LINKS ?
Old May 6, 2009 | 02:41 PM
  #201
Auraraptor's Avatar
Originally Posted by mlandis
Unless I'm mistaken, the car ignores the height settings button over 55MPH -- it goes to the bottom position at that point.
Interesting. I was under the impression the car lowers FURTHER from the lowest setting at high speeds. And this can be compensated by pressing the button.
My 'quick and dirty' test for this confirmed it with a much different suspension feel driving with the button pressed 2x at speed. (if your hypothesis was true, wouldn't it be identical at high speed?)
Old May 6, 2009 | 06:14 PM
  #202
OUTCAST's Avatar
SLK55AMG, SL600
Originally Posted by m4xm1l10n
Should be OK cuz the 305 is big man , i think it would rub w/out the drop anyway
I am running
255/30/20F oops 245/30/20 is up front
305/25/20R
No rubbing at all, but I will let you know after we lower it. You went 3MM longer than the stock ones on the front and 2mm shorter on back. I am thinking from the mounting points is were you measured right?
Old May 6, 2009 | 08:51 PM
  #203
Auraraptor's Avatar
What is your rear offset and width?
Old May 6, 2009 | 10:47 PM
  #204
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Originally Posted by OUTCAST
I am running
255/30/20F
305/25/20R
yes !!!! just make sure the new links are longer "F" and shorter "R" at those measurement i stated . (measurement tape works ) see if the drop is ok with you if not , drop another MM or so , but be careful cuz when i was installing my at first i measured 1" difference between the links and my car just slammed . So star off like i said , the worse than can happen is having your car dropped like mine .
Old May 7, 2009 | 01:09 AM
  #205
mlandis's Avatar
2007 SL550
Woops! My bad. Remind me not to blindly quote others in the future.
Old May 7, 2009 | 11:00 AM
  #206
Sunir's Avatar
SL55 AMG
I have heard the programing differs as well.
What is your rear offset? ET30? I am trying to figure out what rear dimensions I want to build.
Here is the specs I have done for my setup (I may have to do a 20in rear if they don't make my wheel):
I think the programming/settings are different as well.
My rear offset is more than likely mid to low 30's on ET; not really sure, I think ET35, 34, and 32 are all common depending on the outer lip size.
I stayed with 19's instead of going to 20's mainly due to weight of the wheels and the tires at 20" sizes plus a slightly thicker sidewall (35F and 30R instead of 30F and 25R); one big factor is unsprung weight which is a performance killer moreso that sprung weight & it takes more energy to spin 20's than 19's while the difference in contact patch is negligible.
Old May 9, 2009 | 10:51 AM
  #207
mlandis's Avatar
2007 SL550
How do they compare for cornering ability? Does the thicker sidewall on the 19's tires give better side-to-side rigidity than the shorter sidewall on the 20's?
Old May 9, 2009 | 03:09 PM
  #208
Sunir's Avatar
SL55 AMG
That's more a tire design specification rather than a difference in say 35 series tire to 30 series; the physical difference in sidewall is negligible and at 19 and 20" sizes you are still talking about a significant rolling diameter; so sidewall flex may be slightly mitigated if the tire is designed for higher cornering load and properly matched to the rim width.
Old May 10, 2009 | 09:20 PM
  #209
VendettaMB's Avatar
His wifes head hard into the headboard nightly!!
Originally Posted by gqa
here's the link to a thread with some info on the roof module
https://mbworld.org/forums/sl-class-...of-module.html
very nice sl
just read the article, and went to order 1! looks killer
Old May 10, 2009 | 10:21 PM
  #210
VendettaMB's Avatar
What are your thoughts about lowering cars using these links ?
http://www.adjustableairride.com/index.php
I just called them and they are local for me and are going to install for me tomm at 11am, so im super stoked! 450cdn, be in/out and my wife wont even know as we have had the car about 40hours!!
pics will be the before..will post after tomm., will try to take pics of install also.
Attached Thumbnails LOWERING LINKS ?-img_0338.jpg   LOWERING LINKS ?-img_0336.jpg   LOWERING LINKS ?-img_0341.jpg   LOWERING LINKS ?-img_0339.jpg
Old May 10, 2009 | 10:40 PM
  #211
pj57's Avatar
2003 S500; 2004 E55; 2006 SL55 030; 2013 CLS63
Evening project complete! Just installed the links on my SL55 in a little over one hour taking my time, including final adjustments. I lowered it about 1.5" all aroung and am very pleased with the look and ride comfort. Unfortunately, it was too dark to take pictures which I will do tomorrow. Thanks for everyone's installation tips. I chose to keep the rear wheels on during install. If the car is hoisted high enough and you're a fairly good contortionist, doing the rear is do-able without wheel removal. One thing I did was apply a little soapy water to the rubber boots which resulted in easier installation (no pliers needed). To the manufacturer: Nice product! It's probably not possible due to space limitations, but it would be really cool if the links were designed with an adjustment collar similar to a tie rod end so you could adjust the length of the link by turning the collar rather than taking an end off. Pics to follow. PJ
Old May 11, 2009 | 12:53 AM
  #212
m4xm1l10n's Avatar
These links are cool stuff , pics please
Old May 11, 2009 | 04:51 PM
  #213
VendettaMB's Avatar
links installed from John @ adjustableairride.com
So i clicked on the link in the thread last night around 7pm, saw a local area code 604, called it thinking i would get a machine as SUNDAY, mother's day after 7pm..but i got an answer it was John on his cell. I made an appointment for 11am today, and i went in and he installed the links on my '03 sl500. He is super nice, and great to deal with the product is top quality and he installed in w/o taking off rims in about 20-25min!! I showed him where i wanted the height and he lowered it to a really nice drop. I weigh too much and found once i got in it rubbed a little in the front. Hes going to adjust it for me. I raised it up 1 with the suspension and it rides fine now. I'm 6'3, 245lbs, so it drops more when i'm in it LOL.
Great guy, product, so nice to be local and get put in by the guy who made it!
pics show it low, then after raising it with to #1...but its lower with me in it.
last pic is stock.
Attached Thumbnails LOWERING LINKS ?-p5110017.jpg   LOWERING LINKS ?-p5110022.jpg   LOWERING LINKS ?-p5110019.jpg   LOWERING LINKS ?-p5110023.jpg   LOWERING LINKS ?-p5110018.jpg
Old May 11, 2009 | 06:05 PM
  #214
OUTCAST's Avatar
SLK55AMG, SL600
Nice drop looking good!
Old May 11, 2009 | 06:23 PM
  #215
m4xm1l10n's Avatar
Looks fantastic but dam do you drive that on dirt roads ? lol
Old May 11, 2009 | 06:26 PM
  #216
VendettaMB's Avatar
thx, looks way better now. cheapest, quickest drop ive done to any car.
washed it on sunday, and then it rained today! i also got lost trying to find his shop as i just moved here and did a few hasty u turns, along side of road.
Old May 11, 2009 | 06:36 PM
  #217
m4xm1l10n's Avatar
Took me 30 min to install mine the first time !!! and how much was installation ?
Old May 11, 2009 | 07:03 PM
  #218
VendettaMB's Avatar
they are 300usd off webpage i think and 25usd shipping. i paid 450cdn, and had it done within 20hours of phone call. no shipping time, brokerage etc to deal with. it was an unexpected bonus to have him so close.
pic of stock height side
Old May 11, 2009 | 07:26 PM
  #219
m4xm1l10n's Avatar
HUMM $150 You could flew me down there for that money HAHAHAHA here is mine again dropped .
Old May 12, 2009 | 01:44 AM
  #220
VendettaMB's Avatar
300 usd equals 375+cdn, without install/shipping /brokergae/tax etc,//LOL
im flying to la this month for 16$ on allegiant air
Old May 12, 2009 | 01:45 AM
  #221
VendettaMB's Avatar
with this! lol..i miss the forums..
Old May 12, 2009 | 09:34 PM
  #222
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
that's the kind pf drop that I like.
Old May 12, 2009 | 10:14 PM
  #223
mlandis's Avatar
2007 SL550
So do you find the handling improved with this model?
Old May 13, 2009 | 03:19 PM
  #224
mtlbenz's Avatar
Sl500R
My links are for sale!!
Hey Guys, I just sold my SL500(R230) and I kept the links. So if anybody wants them they are up for sale. They have about 300miles on them, I'll sell for 250$ SHIPPED!!!
PM me, or email me
nickdfg@gmail.com
Old May 13, 2009 | 06:44 PM
  #225
VendettaMB's Avatar
when my wiferides with me it's always good handling!!
