SL/R230: B Service Worries
Old May 24, 2009 | 10:49 AM
SpainSL500's Avatar
SL500
B Service Worries
Hello All:
I was being a little cheap with my 05 SL500 which has about 23,000 miles. The B service indicator came on, and I decided to take to a "European Specialist" garage as they were only charging 200 bucks for the B service. Anyway, I got home to find out my tire pressures are now all out of whack. Also, doesn't look like they changed the air filter (I only know cause they didn't bill me). Anyway, they put synthetic 5W40 in my car.
Couple of questions:
Is the oil they used ok?
Can I change the air filters myself? I'm not very mechanically inclined, so is this easy?
Thanks for your help.
Old May 24, 2009 | 12:11 PM
jmf003's Avatar
'03 SL55
Originally Posted by SpainSL500
... Couple of questions:
Can I change the air filters myself? I'm not very mechanically inclined, so is this easy?...
5W40 is fine as long as it's one of the MB-approved synthetics: http://www.whnet.com/4x4/oil.html. It's not the end of the world if they didn't use an approved synthetic but you'll want to make certain to use the approved stuff the next time around.
It's very easy to change the air filter yourself. The biggest risk is dropping the screws into the engine compartment after you remove them.
Old May 24, 2009 | 01:57 PM
SpainSL500's Avatar
SL500
Thanks very much. Can you tell me where I can find the air filter and the screws you refer to?
Old May 24, 2009 | 03:45 PM
Artyi's Avatar
Mercedes-Benz SL 500
I just made a B service and they changed me a gearbox oil, also put into engine 0W40 oil...
