SL/R230: Convertible top won't open...Help!
Old Jun 12, 2009 | 10:21 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Before I send this to the dealer, I was wondering if someone might have a fix...
I keep getting "close trunk partition" message whenever I try to open convertible top. Every time I check the trunk and the trunk partition is in place...Is there contact not meeting or a switch not working?
Old Jun 12, 2009 | 10:44 PM
n2red's Avatar
2003 SL500
Yep..... sounds like one of the contact switches that close when the cover snaps into place isn't closing. Simple to diagnose if you're handy with a multimeter. Check for completed circuit. Do this with the ignition off.
Old Jun 13, 2009 | 03:41 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
You probably did this 100 times but did you check if anything might be in the way??? Most likely it is the Switch not working I'm no wiz but sounds like an easy fix.
Old Jun 13, 2009 | 12:54 PM
AMGfan's Avatar
FIXED!!!!
Took it to my tuner shop...they came in on a Saturday for me.... The plug to the partition switch was unplugged. There was some work in the back panels and apparently the person putting the car back together forgot to plug in that switch.
