PIcs of my JL 13.5" sub installed in footwell & sport bmpr W/lip (inspired by AMGFAN)
Subscribe
Aug 29, 2010 | 01:49 PM
Very nice install for sure.
Reply 0
Oct 23, 2019 | 06:16 AM
I know this is an old post, just need some info.
I really want to install a JL shallow mount sub in place of the stock sub and have the following questions.
What is the model of the shallow mount sub people have used?
How is this mounted, is the old plastic chamber with the vent pipes not used and a new enclosure made?
What is a good way to change the input speaker wires to RCA inputs for a sub?
Thanks in advance.
Reply 0
Oct 23, 2019 | 03:40 PM
I used the JL 13tw5 like amgfan and others, it works great. You remove the old Bose setup and will need a custom box to be built, likely out of fiberglass because of the odd shape. You will need some sort of line converter to change the speaker signal to RC input (there are several brands out there).
Reply 0
Oct 23, 2019 | 04:22 PM
Quote: I used the JL 13tw5 like amgfan and others, it works great. You remove the old Bose setup and will need a custom box to be built, likely out of fiberglass because of the odd shape. You will need some sort of line converter to change the speaker signal to RC input (there are several brands out there).
Great thanks, I take it you'll also need an additional amp too?
Reply 0
Oct 23, 2019 | 05:20 PM
You are correct. I mounted mine in the trunk near the battery.
Reply 0
Oct 24, 2019 | 05:14 AM
Quote: You are correct. I mounted mine in the trunk near the battery.
Great. Can you still fit the spare wheel, what was the amp you used?
Reply 0
Oct 24, 2019 | 12:06 PM
  #32
I actually built a wood frame and mounted it toward the cabin so I could still have the spare, but others have mounted it below (I'm also not sure I'd risk trapping all of that heat in there). I believe the amp I have in now was a kenwood excelon xr-1s, mainly because it has decent power, small form factor, and had the remote bass knob that fit perfectly in the ashtray slot up front.
Reply 0
Subscribe
Currently Active Users (1)
