SL/R230: Shopping for wheels, what do you think?
Old Oct 13, 2013 | 05:07 PM
SL4Life's Avatar
On my 3rd coupe!
I'm getting an amazing deal on these wheels and about to pull the trigger. My only hesitation is that the rear offset is +45 so I'll have to use spacers. I'm not much of s technical guy so I thought I'd ask here first If you guys think that is ok and if there are any cons to using spaces. The wheels are 20x8.5 front & 20x10 rear. The lips are 1.5 front & 3.5 rear.
Your comments and advice is appreciated.
Old Oct 13, 2013 | 08:44 PM
SL4Life's Avatar
On my 3rd coupe!
Old Oct 14, 2013 | 10:01 AM
Benz-O-Rama's Avatar
My opinion is to buy wheels that fit. Don't buy wheels that you'll have to adapt to fit. Spacers commonly introduce vibrations, not to mention, you'll need to buy longer wheel bolts.
Old Oct 14, 2013 | 12:07 PM
fxrs1955's Avatar
2014 SL550
+1
Old Oct 16, 2013 | 03:14 PM
COMEINPEACE's Avatar
05 SL500
DITTO..... no spacers.. this is a heavy vech.
the wheels are beautiful though
Old Oct 20, 2013 | 09:46 AM
SL4Life's Avatar
On my 3rd coupe!
Well after further research of our vehicle specs, it appears that the SL's off set tolerance is +35 to +45. These wheels are +43 so I'm hoping I'll be ok!
See attached:
Old Oct 21, 2013 | 12:16 AM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
Weird how it shows 01-on.. (is that the european model year life cycle?) and it doesn't mention wheel width... which makes a difference if you're not using stock width.
Old Oct 22, 2013 | 09:54 AM
SL4Life's Avatar
On my 3rd coupe!
I suppose there's no reason to mention width if the offsets are based on factory wheels. Also, w230 instead of r230 does indicate that it's the euro model but I always thought their life cycle was from 2002+ so yes that is weird.
