titup |
10-02-2014 08:41 PM |
07 SL550 won't start - starter doesn't engage
Hey Guys, I posted this earlier but I think I posted it in the wrong place..... anyway does anyone have a suggestion on getting this thing started? Thanks for any help!!
I have an issue that I am having difficulty diagnosing. I have 2 SL550's both 07's, a black one and a white one so it is easy to swap parts to diagnose a problem. After driving the black car for a while knowing the start battery was going bad, my wife came home with it running fine and after turning the car off it will not start... starter will not engage doesn't even turn over. So knowing that battery was bad I went to the Mercedes store and bought a new starter battery thinking that had to be the problem. Replaced it and still have the same symptom. using either the keyless go or placing the key in the ignition the symptoms are the same..... starter solenoid doesn't engage. I know both batteries are good b/c I swapped them into the white car and they worked fine..... Is there some sort of starter relay or security mechanism that prevents the starter from engaging..... I have checked every fuse in all 3 fuse panels and none are blown. Is there anything anyone can recommend that I try? Thanks
