SL/R230: Gas Tank Rattle
2004 Mercedes SL500
Gas Tank Rattle
I have what I assume is an unusual problem. There is an annoying thumping sound when the car moves or stops. I can make it happen by just pushing forward and backward on the car even when stopped. The MB dealer has identified it as a loose baffling in the gas tank. Makes sense. Their answer is to replace the gas tank at about $2500. Anybody have a much simpler and cheaper answer?
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
fix gastank
i had same problem on my old 2005 SL55.. they took out the tank, is big job, need take off the roof . we cut it open,and welded it solid,and put it back in.. is alot of work in and out . can be good idea have good welders do that job, and have a good mecanic take out and in again. make shure pressure test the Tank and make shure no micro holes..
2004 Mercedes SL500
Gas Tank Rattle
Thanks for the responses. So far I like the spring down the gas fill pipe approach given difficulty and cost of tank removal. I may check to see if someone has a camera fiber tube or probe (besides my proctologist) that may help to see what the situation is. Anything that might spark, though, seems ill advised.
