SL/R230: 2003 sl500 jack pads
Old May 9, 2015 | 03:23 PM
sinnedsl500's Avatar
sl500
Does ANYONE out there know where to buy new jack pads for 2003 SL500 ???? I can find them everywhere for years up to 2002. They look identical. What's up with the hole diameter?
Old May 17, 2015 | 08:27 AM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
You might find what you're looking for here:
http://www.prothanesuspensionparts.c...-jack-pads.asp
Old May 20, 2015 | 11:44 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
If you are talking about the hard rubber/plastic plug (approx 2" major Dia) that is attached under the car at the sides (at the jacking points), I just replaced 2 on my 2003 SL55 and the part number is 0029970686 . It is referred to as a "plug" and goes for $7-$10 each
http://www.oediscountparts.com/parts...&siteid=215242
this link is higher priced, but lists the applications
http://www.mbpartsworld.com/p/Merced...029970686.html
Cheers,
Chris
Old May 20, 2015 | 11:47 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
bought mine at autohausAZ.com
Old May 21, 2015 | 03:23 PM
sl500
Yes, you are correct about the part # Technically it is referred to as a plug. You will not find this thing under the description of just PLUG. The dealer referred to it as a jack pad. On the schematic it just says PLUG. There are a lot of items called PLUGS on the frame of the car. I spent a couple more dollars. Wish you had of seen the post earlier. Oh yeah, it's 30mm. Different chassis do have different size holes. Crazy stuff....... Thank you for the site info.
