SL/R230: Help glove compartment won't close
Old Nov 6, 2015 | 08:15 PM
tdub57's Avatar
2003 SL500, 2002 CL500, 1995 C220, 2019 GLS 450
My glove compartment won't close. Somebody please help!
Old Nov 7, 2015 | 09:19 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Don't try to slam it. It will break...mine was when I bought the car.
There are 2 rubber head screws that act as stops. Turn these in a rotation or 2 and see if that works.
Check the latch for being loose. If it is wobbly, you may need to remove the box to tighten some screws, or look for Torx screws that are on the top edge.
The side panel by the door needs to pop off if you remove the box.
If the plastic is broken, you can try to reinforce it with a sheet of aluminum and rivets. Otherwise replace it.
Good luck!
Old Nov 7, 2015 | 09:29 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
I had a different problem on my recently purchased '03 SL. My glove box would not open. Try as I may, I could not get the latching mechanism to free up. I wound up removing the entire glove box and freeing up and lubing the sliding mechanism on the bench.
You might be able to adjust the door but most likely something is stuck.
Good Luck,
Bob
File Type: pdf
File Type: pdf
Old Nov 7, 2015 | 04:18 PM
TTtodd's Avatar
2005 SL65
I had problems with mine, now its been over a year with no problems after this adjustment.
http://www.benzworld.org/forums/r230...ment-wont.html
